after lam'ing the bottom,what is a good amount of time to wait until the top is to be done? how long to wait for lam. to cure before doing the hot coat? and finally, after doing the deck with the hotcoat, how long before doing the bottom? oh ..one more.....after the hotcoat, how long until it is able to be sanded?...................................about 65 degrees and low humidity.....
>>> after lam'ing the bottom,what is a good amount of time to wait until the > top is to be done? how long to wait for lam. to cure before doing the hot > coat? and finally, after doing the deck with the hotcoat, how long before > doing the bottom? oh ..one more.....after the hotcoat, how long until it > is able to be sanded?...................................about 65 degrees > and low humidity..... ...............It can veri from an hour to a couple of hours.The surface of the lam should be STIFF.However,if you don't have to turn the blank over(deckside)you can hotcoat say 15min. after a solid gelling. Teddy,try to get some U.V. CATALYST you can add it to the resin and do a ALL U.V. resin job or mix and match UV/MEKP batch. The reason for the UV cat is it reduces standing around time by 80-95%.Herb
>>> ...............It can veri from an hour to a couple of hours.The surface > of the lam should be STIFF.However,if you don't have to turn the blank > over(deckside)you can hotcoat say 15min. after a solid gelling.>>> Teddy,try to get some U.V. CATALYST you can add it to the resin and do a > ALL U.V. resin job or mix and match UV/MEKP batch.>>> The reason for the UV cat is it reduces standing around time by > 80-95%.Herb Herb are you in so. cal. if so do you know anyone in San Diego that sells the uv catalyst? thanks mark http://www.scottsurfdesigns.com
>>> Herb are you in so. cal. if so do you know anyone in San Diego that sells > the uv catalyst?>>> thanks mark...........No,not directly,Basham's might sell it,I'm not sure if he does either?Surfsource sells it by mail.Sorry if I couldn't be more help.someone here should know.Herb
Scott surf design - I just received reply to similar question direct from Suncure. Thanks John, Sun Cure Ultra violet catalyst comes in 3 sizes: 1 gal pack - $4.75 10 gal pack - $22.95 and 55 gal drum pac - $120.00 No haz mat fee. Call us with credit card to order. 904 247-0808
