>>> anybody ever try fixing deck delaminations by injecting liquid urethane > glue.brand name gorilla glue.it is a expanding urethane foam glue.>>>>>>>Lam resin is the best when it comes to injecting under the glass.I sometimes use a low rising poly foam,but it can create a bigger problem than you start out with.>>>>>>>Gorrilla glue? it has a brown color to it,correct?Herb
yea it's brown colored liquid,dries neutral color but not pure white. reason i was thinking to use it instead of lam resin is it works in the presence of moisture and after a week of drying out my 9'10" noserider is still water logged. guess i could wait longer and see if it dries out,hate to wait..........my friend used the gorilla glue and says its compatible with surfboard foam and sticks like crazy.
>>> yea it's brown colored liquid,dries neutral color but not pure white. > reason i was thinking to use it instead of lam resin is it works in the > presence of moisture and after a week of drying out my 9'10" > noserider is still water logged. guess i could wait longer and see if it > dries out,hate to wait..........my friend used the gorilla glue and says > its compatible with surfboard foam and sticks like crazy. .......Unless gorrilla glue is a waterbased glue that dries waterproof............... trapping water into the foam(especially air-tight) will cause serious damage to your board down the road!Always dry out your dings completely,and never shovel wax in the ding,either.Herb
You US guys use Gorilla Glue a lot with good results, anyone know whats the name of a similar glue in Australia?
Or where to source Gorilla Glue for import ?
Thanks.
