>>>hey teddy, I'm not jumping in on Kokua but I've found a knitting needle in your rail tool instead of a pencil leaves a small clean indent evenly as would the pencil without the visible lead line.This method is virtually invisible under any lam...
>>> when you do a resin tinted lam, do you eyeball the tapeline, or use > pencil?? I eyeball all my tape offs,be it tints,opaques,or airbrush work. I tried a cheater tool once back in the late 60's and didn't like it. There are a lot of glassers who use them but their not my cup of tea. Aloha,Kokua http://www.yahoo.com
>>> how do you get the needle to stay in place on the rail line tool? Teddy I use a piece of L shaped foam ( an off cut ) and simply push the needle through the foam.Make sur the section of foam you are pushing the needle through is say 2" thick and the needle should stay in place fine if not try some plasticine. This also works for pencils.
>>> plasticine? not familiar with it.. ever try putting the needle in a wooden > set-up? Plasticine is play dough and I've always just used scrap foam for my marking tool but I'll get one from JR when he has them ready...
plasticine? not familiar with it.. ever try putting the needle in a wooden set-up?
