>>> Ok Gentlemen:>>> All things being equal-- same board, same fin, same toe in. One rail fin > is tilted off verticle 4 degrees out from center, another 16 degrees out > from center. How does the two differ in performance?>>> Better Surfin', Rich What would the riding characteristics of a thruster be if the side fins were placed closer to the rails (stiffer??) or in closer towards the stringer-relative to most thrusters being ridden nowadays. Thanks, Graham
>>> OK. here is my .02 worth. This all revolves around my messing around with > twin fins on older Fish outlines. My old Sunset Cliffs shape twin had two > parallel-to-stringer and zero cant. It was stiff and tracked for my > average conditions. When I stumbled through the door here at Swaylock's > back some 2-3 years ago I was searching for fin specs. In time I found > that with the right cant angle helped in getting that wide 17" tail > over on the rail. The toe-in stuff just allows you to control the turn > radius, more toe-in=tighter arc.>>> Now for a question. I'm going to make my son a new grom type board, 5'6- > 5'8 chip etc. I'm thinking that with the lighter weight of the rider and > the really shortened rail line then the fin placement (tri-fin) needs to > be adjusted, further back it would seem. What kind of numbers are some of > you using in these really short shortboards? In other words, trailing edge > to tip for Center and Side fins?>>> Tom S. Tom i build a lot of small boards and in that 5'8 range sides 10 1/4 to 1/2 back 3 1/4 but toe them off the tip groms really don't go rail to rail enough to feel the difference. I'm building my girls new boards fr this summer. they weigh about 60 each so i'm thinking about 5'9 x 17 x 2max thin rails Rob
>>> Ok Gentlemen:>>> All things being equal-- same board, same fin, same toe in. One rail fin > is tilted off verticle 4 degrees out from center, another 16 degrees out > from center. How does the two differ in performance?>>> Better Surfin', Rich Ok i hope i'm reading right. 4 degrees will drive more but tend to slide more then the fin at 16. more cant will hold thru a harder turn. Say off the top 16 will hold in better then 4.. 4 will get you around a section better in a longer arc and carry more speed. Then again you never said how much toe??? that would make a big difference. on my boards i tend to go with less cant and less toe but we ride very short flat boards in bigger waves then most in the northwest.. Rob
>>> Alright cut the crap guys.I,m an old geezer and this tech stuff flys over > my balding head.Tell me this...if I cant the fins more outboard what will > it do?If cant em inboard what will it do?Also if I change the toe in what > will it do?Make it simple...kinda like talking to a child so I can > understand.Thanks....R.B. The more outboard more turn with less effort. \__/ The more inboard the more drive better arc. |__| More toe ( / \ )more "slow" no down the line drive but it will turn on a dime. Ok you balding old resin sniffing geezer.. I hope that makes it easy to understand... Rob
>>> Ok i hope i'm reading right. 4 degrees will drive more but tend to slide > more then the fin at 16. more cant will hold thru a harder turn. Say off > the top 16 will hold in better then 4.. 4 will get you around a section > better in a longer arc and carry more speed. Then again you never said how > much toe??? that would make a big difference.>>> on my boards i tend to go with less cant and less toe but we ride very > short flat boards in bigger waves then most in the northwest..>>> Rob Seems logical to me... though I would guess the most noticable differance would be more lift and more drag in the 16. And turns... better? ... maybe not, just a helluva lot more squirly... could see it slippin out on a steep wave if your trailer wasnt big enough
>>> Seems logical to me... though I would guess the most noticable differance > would be more lift and more drag in the 16. And turns... better? ... maybe > not, just a helluva lot more squirly... could see it slippin out on a > steep wave if your trailer wasnt big enough -- Anytime that outside fin, or it`s tip, moves closer to the rail`s edge, the overall hold will be better.
>>> -->>> You`re right... more cant + more speed = more lift. In fact, after a > certain velocity, the tail will start to rise and handling becomes a > serious problem. Combine cant with edge fins which are only foiled on the > outside/flat on the inside, plus toe-in and you have a configuration > that`ll always be trying to crank around and back up the face.>>> The built-in dilemma with thruster fin set-ups is the fact that at any > given time, two of the fins are in directional opposition to the (inside > edge) engaged fin. Lots of drag means lots of control in this case, but > also a significant loss of top end... one of the primary reasons these > designs must continually be pumped rail to rail in order to maintain and > develop speed.>>> Small, active "paddle fins" (twist/flex concentrated in the > narrow base) really help in resolving the common problem of three, stiff > base thruster fins all working against each other. check out Jim Banks fin system. works to alleviate this problem of three fins going in three different directions. Very smooth, fast and incredible in the barrel. www.speeedfins.com yes 3 e is correct. very slick system with no-through deck drilling or screwing that will eventually lead to water absorption that plagues the sytems that use this technique.
>>> The more outboard more turn with less effort. \__/ The more inboard the > more drive better arc. |__| More toe ( / \ )more "slow" no down > the line drive but it will turn on a dime.>>> Ok you balding old resin sniffing geezer.. I hope that makes it easy to > understand... Rob Finally a straight answer.Muchos crotchias Rob............R.B.
>>> check out Jim Banks fin system. works to alleviate this problem of three > fins going in three different directions. Very smooth, fast and incredible > in the barrel. www.speeedfins.com yes 3 e is correct. very slick system > with no-through deck drilling or screwing that will eventually lead to > water absorption that plagues the sytems that use this technique. Cripes I'm getting confused again when I thought that Rob had me straightened out.If I blindfolded you and changed the cant and toe in would you know the difference??????......R.B.
>>> -->>> Anytime that outside fin, or it`s tip, moves closer to the rail`s edge, > the overall hold will be better. I'm not sure I agree with that in full, use extremes... what if you put in 60 degrees cant... what about 90. You'd get plenty of lift, but it wouldn't hold worth a dam.
