Does anyone know if Steve Forstall is still cuting those "codacore" blanks or of any other decent EPS blanks out there. I really like the few coda I worked with, they are the closest thing to close to shape EPS I have seen. They really did not require nearly as much work to fix the rocker and other issue in some of the styro blanks being cut/for sale these days. anyone... anyone...
HDX surfboards in Huntington Beach has blanks for sale. If you'd like to check them out, please drop us a line at 714-379-5533 or 714-404-1663 http://www.hdxsurfboards.com
Jim, if you could please provide me any info you have on stringer options (wood/composites); general blank dimensions; pricing, etc.
If you meant Jeff, the prices vary according to what you want. We make close tolerance blanks to order. If there is a special stringer set up you want, i.e. 1" redwood, 3 stringer oak with green glue, 1/4" mahogany, we'll make it! If you didn't mean Jeff, disregard the above info... http://www.hdxsurfboards.com
Coda is still making blanks. Davo and Resin Research also suppliy blanks in that area.
CodaCores can be reached at 321 676 5307, Steve Forstall one of the best shapers on East Coast...
Hey thanks everyone. Jeff I will try to give you a call and discuss various blank options. As near as I can tell you have both extruded and expanded poly, so I might want to do a trial run of both. Everyone else, thanks for the codacore info. I had that number for steve. i think it is is home number. I have not been able to get in touch with him in awhile. Spoke with him 3 years ago when I first tried the codas...
