What would be the best blank to get the most kick in the tail and flattest nose rocker? What is the technique used in getting tail rocker? How much tail rocker would you suggest for a killer noserider? Thanks so much! Tim
>>> What would be the best blank to get the most kick in the tail and flattest > nose rocker?>>> What is the technique used in getting tail rocker?>>> How much tail rocker would you suggest for a killer noserider?>>> Thanks so much!>>> Tim 9'1Y has a good noserider rocker almost 4" in the tail and only 4 1/2" nose, its also really 9'3" long, or scale it up to the 10'1Y for a real noserider! 4+" is what my ten foot noserider has and shaped with a rounded vee(last third) all the way up to the deck(up rails in tail,down rails in nose, 60/40 mid) it is a hang ten machine, any longboard is hang five-able but for ten, (and I get it all the time!) get classic foam,18-19"nose w/concave, low 4.5" nose rocker,lotsa tail rocker and board length w/sinlefin, cause nuthin' blows their minds more than a solid ten noseride..........!
What about this setup, low nose rocker with flip in the tail for performance pig or evolution type boards? Basically boards not made for noseriding but trimming and turning? How would having tail flip to turn vs. natural with vee be different?
