Ideal Blank for a 6'4" Takayama Scorpian 2 type of board
23 posts |
sandstone's picture
Its finally time to shape my first board. I am wanting to recreate something like a Takayama Scorpian 2 @ 6'4" or so and would like to get input on a suitable blank for a first time shaper to work from. I will likely be buying my blank and shaping the board at Foam-EZ. I am 5'6' and 160 # solid surfer of 20 + years. Any suggestions would help greatly. Here are a couple of images of the model.
Thanks
johnmellor's picture
From what I know of that board, it has what is essentially a longboard front end with a wide outline, flat rocker and slight concave.  You could shape it from a number of blanks but in the interest of making it as easy as you can without overshaping to soft core, you need to find something as close to the finished shape as possible.  Most of the mini longboard blanks are longer than what you have in mind so although they look good, will require quite a bit of thickness profiling once the outline is positioned and cut.  Another option is to get something closer in thickness, but most of those seem to have too much nose rocker.  I'd say your best option is likely going to be one of the 'egg' blanks with a custom ordered reduced nose rocker.  Print out those images, run them through a copying machine that allows you to enlarge/reduce and make adjustments until you have a print out showing the board image at about 6.25 inches long.  Measure back 1" from the tip of the nose and check the width.  I'm guessing around 1.75" which after scaling up = 18" wide or so.  The toughest part of choosing a blank for that one will be fitting the nose width to the rocker and not having a really tweaked thickness profile.  I'd recommend the USBlanks 6'10"A with nose rocker reduced by an inch.  I think it will fit, the nose outline and nose rocker won't be too far off, and it's about the thinnest blank in that length range to avoid overshaping and a lot of extra work.  Your outline template will need to be shifted back a bit for the nose outline.  Double check your dimensions once you do the copy machine deal but that's my best guess.
http://usblanks.com/catalog/fish-eggs/610a/
PS - If you're up to designing your own profile and EPS is OK, you might try designing your own blank.  USBlanks will cut your profile or Marko can machine shape the whole thing to your file for a really close tolerance blank.
McDing's picture
I hate to say it; but that is such a convoluted shape for that size that it Is fully ridiculous.  It is completely stupid to shrink a shape down below certain sizes.  And this is your first board????  Get real!!!  Find something more realistic to shape.  Seriously!
Li'l Smokey's picture
First, I don't see anything unreasonable about the shape as a first project at all. The idea of making boards is to get what you want, and that's what you want. My buddy had local PNW shaper, Scott Rowley, do this one for him (Glassed at "El Brado's" in Camas). They shaped it from a 6-5A. I don't know about any little tweaks to rocker or thickness, but I know they got it out of a 6-5A, and the board RIPS. I am a beginner myself, and have found that getting the concave right without messing the rocker is tricky, but there is only (and only!) one way to learn. Advice is helpful, often necessary, but you gotta get out there to really feel it, right?
I have found the a "curve-reader guage" or contour guage is super helpful in duplicating boards (rails). Harbour Freight has a plastic one for about $5. Be sure to wrap a piece of sandpaper or similar over the rail before you push it onto the blank so that it doesn't gouge the foam.
So, yeah. 6-5A. You will learn alot and have a ton of fun! Good Luck!
PS: Photo: (L) Nate King, "PAR Surfboards (R) Brad Kavonius "El Brado's Fiberglass and Board Repair"
SUBPAR's picture
SUBPAR (not verified)
That's me with the death stick, and the board I just talked about. further memory corrected the 6-5a blank to the 7-4a blank. rocker is flat...nose rail is drastically rolled up.
SUBPAR's picture
Dang McDing, just critisism without being constructive is pretty lame. Who pissed in your cherios before you typed that reply....?
I had a local shaper make me a similar board and it's tons of fun, he ran it out of a 7-4a blank and set the template accordingly...It's a single fin 6-4, goes great in waist-head high Oregon waves.
McDing's picture
It' has taken me quite a few years of experience to come to the realization that shrinking a longboard down to six or seven foot is a waste of time.  Hell! It's a waste of good foam.  The same could be said of shrinking a 6'2 Shortboard down to a 5'8" for a 175 lb guy who in his convoluted mind thinks he's 150 and surfs like a pro..  You have to get to a place in your life where you will turn down a custom order and the $$$ when someone wants you to do something ridiculous.  A longboard is a longboard.  A Shortboard a Shortboard etc.  shaping a six ft longboard is a novelty.  Not saying it's not rideable and not saying it won't ride.  What I am saying is this time next year you'll be thinning your "quiver" on Craigslist PDX and we'll see it listed there.  You'll extoll how cool it is etc. and tell us you gotta new baby on the way and it's gotta go.  There's  a lot mo betta things to shape out of a 6'4 or 7'4A.
SUBPAR's picture
Opinions are cool to have. Maybe the guy makes this board and it enlightens him to the fact that surfing is a personal experience, maybe he is already privy to this knowledge... maybe we see him dumping his made overseas “cool guy” boards on Craigslist to buy more materials to continue down the road of maybe being one of the next great shapers.
Maybe he disappears off the face of the planet.
Maybe Donald Takayama didn’t actually know how to shape anything “worth riding”.....naw
McDing's picture
No use to jump to conclusions about DT nor impugn his ability just because I think that a shrunken down longboard is an over the top choice for a first time shaper.  But all of this bitchin' and sensitivity around here is pretty much the norm for first timers on Sways.  If I were a first time shaper/glasser/board builder and self styled expert as many are here;  the first board I shaped would be the most difficult design I could find  Lots of channels, a full concave single to double with V out the back to of course "Spiral Vee".  Glass with Hemp cloth that I smoked a little first.  A Mexican Blanket lamination with a cork deck and a veneer bottom.  For resin I'd use the latest Boutique Epoxy mixed with Wesson Oil.  I think something like that "Salad Sap" Quik 'n' Fast stuff.  I'd cure it in a micro wave for a month and then take it out to Short Sands, drive back to Portland that PM.  Get on Swaylocks and rave about the ride report.  Wait a month or so and the put it on Craigslist under the title "Thinning My Quiver".
I only see one guy bitching on this thread. Everybody else seems like they're trying to build some boards and have some fun. We are talking about surfboards, afterall.
SUBPAR's picture
I have no idea what your problem is....you happen to be Lowell out of pc?
SUBPAR's picture
Hahahaha! After a little searching you totally are!!!! HAHAHAHAHA! Like you have earned the right to talk shit on anyone or anything!! Hahahahaha! !!! Funny I surf pretty much every break from Hobuk to Brooking 2-4 days a week year round. For you being a local guy i’ve Never seen you or one of your boards in the lineup! Or in any spot without a lineup! Hahaha!
So, It seems that was taken from a 7-4A, as SubPar has just corrected. Sorry for the bum steer, I guess it took Nate a minute to remember! As he said, a really, really nice board!
That PNW board turned out really nice. Mind if I ask what the nose, WP, and tail dimensions are?  I'd be interested in comparing to the dimension diagram on the 6'10" egg blank to see if it would fit.
SUBPAR's picture
I’ll put a square on it tomorrow
SUBPAR's picture
18.25 nose,  21.25 mid +2, 15.5 tail and a general rocker profile...
sandstone's picture
Thanks Guys for the input, I can't find the 7'6A blank on EZ foams website but was thinking that I could posibly use a retro fish blank such as the Marko 6'6 halibut or US Blank 6'8RP fish. There is also the 7'4SP egg. I'm not going to be making any complicated bottom contours, just a little nose concave. The idea for this design will be creating something that will have a predicable ride (single fin set up) and ride variation from the other avaialbe fin set ups (quad, 5 fin, thruster). Hoping to gwt started as soon as next week or when I settle on an appropriate blank.
Hi sandstone -
In comparing those dimensions with the expanded dimension diagram on the 6'10" egg blank, I think you'd do fine with it.  It looks like a pretty good fit but you still might want to reduce the nose rocker a bit if you have the option of ordering anything custom.  The nose, tail and widepoint widths should be OK for sure.
HelterAgain's picture
Never seen one of those buut that's a beautiful shape. I might try one myself. looks ripe for bonzifying! Good luck and looking forward to seeing how it goes
Huck's picture
gdaddy's picture
McDing definitely does have a point about loading too many features into your first few shapes.   It's important to get a handle on the basics.  Shape comes first.
The shape is legitimate, but most shapers who have been doing them have used slightly longer lengths and run them as singlefins.  The reason being there's a lot of width/curve going on in a short length so that's going to slow the board down regardless of what fin setup you use.   You surf a board like that when you WANT to go slow and stay with the wave, in which case you want to get some glide going.
For blanks, I'd use a 7-4SP 'cause that's a good egg rocker, and then take a 6-10 length out of the middle.  A little roll in the nose, a slight belly or chine through the midde and fade into a shallow vee panel with a hard edge in the tail.  Basic.   If you can do that shape cleanly the board will be loose and have a nice little glide going for up to head high summer mush conditions.
Just my opinion.  I think the 4+1 setups are bad news because there are too many compromises going on.   The bottom contours that go with surfing the board as a quad don't work as well when surfinf the board as a single and vice versa.  Better to do one thing well than three things less-than-well.
SUBPAR's picture
Nailed it
McDing's picture
“Subpar”. Ha!  Now that’s a nickname that’s not convoluted at all.  Fits perfect.  IMHO. And if you can’t take it.  Hit it.  I’ve sold quite a few blanks,cloth and resin over the years here in Oregon and what you see or do doesn’t mean shit to me.  You ought to try getting out of Brookings and Oregon in general once in awhile.  Might open your mind to a world of possibilities.  You’re such a gnat on my ass I didn’teven Notice this thread got moved.  There’s more to life than Sways—SUPar.
Topic locked
