Tried my hand at a foam stain last night and didn't end up with the exact results I was looking for. Wondering if I did another coat if it would clean it up or any other tips for getting a more solid color? Or just leave it as a lesson learned.
Way too thick. You want to paint the foam with the resin like an airbrush, not put a shell on it. We're talking about a really small amount of resin. You should still be able to see and feel the details of the texture in the foam and stringer.
I think you're going to have to sand that flat before you glass it. Gently
Yes, was EPS foam. I ended up doing a resin tint which I probably should have just done in the first place and skipped the foam stain, live and learn. Anyway it turned out pretty decent., going to add a pin line around the lap on the deck. Just hot coated today. Board #7
I really. Don't understand why you didn't just paint the blank red. If consistency and evenness was what you desired; a red spray job would have done the trick.
Hi sir,
What kind of blank did you use ? Was it EPS ? In my opinion it looks like it was put on too thick ?? Again that's just my guess.
Mainly because I'm a newbie and didn't know any better, also experimenting with different methods.
