My recently acquired skil didn't have any dust chute or vacuum port, and I wasn't about to spend 75 bucks for one
parts: 1 x 1 x 1 T fitting
2 end plugs
i found a rain gutter end cap to use as the base plate , cost 2 bucks.
Measured the opening and dremeled out the base plate
cut open the T fitting bottom and sanded it flush
epoxy resin t fitting to base plate
dremeled out hole
cost 9 bucks for the parts
you can take out and end cap and throw it on top if you don't want to use the vacuum hose and it'll spit out, left or right
Perfect! Thanks for the technique !
Surfer-world represents passion and experience from more than 25 years in field of water sports.
