I did some experiments to see where my issue was. I took some of the rail off cuts, along with the same 6oz glass and poly lam resin to avoid any unwanted variables.
#1- paint thinned with distilled water, dry a few days, poly lam resin with 6oz (original process)
#2- paint thinned with distilled water, dry a few days, squeegee on thin coat of lam resin and let cure, poly lam with 6oz
#3- paint thinned with behr low-lustre concrete sealer, poly lam with 6oz
#4- distilled water sprayed through airgun, poly lam with 6oz
#5- acetone sprayed through airgun, poly lam with 6oz
Conclusion: as mentioned earlier, it seems to be an issue with the paint. The compressor/airgun setup doesn't seem to be introducing any contaminants. The squeegee coat of resin pre-lam seemed to help a little, but didn't eliminate the issue. Thinning with the concrete sealer worked well. I'm sure the catalyst/temp/etc weren't exact because of the small quantities, but I tried to get as close as possible.
In the future, I would recommend against using the "folk art" brand of paint. It may just be the purple pigments, as I have used other colors in the past. But it was clearly an issue with the paint this time.
Honestly if I were to paint a board in a dark color I would use house paint. Flat interior house paint. I have done Turquoise and deep blues in the past with "flat" cheap interior house paint. Good results and no crystalization.
I just want to thank the OP for posting this. I've heard the horror stories about crystallization for years, but never really seen a good example of it. This was pretty epic. And good job with the systematic experimentation. I know it wasn't the desired effect, but I think the snowflake look on the bottom is actually kinda cool looking.
IMO Behr also goes on more evenly and just feels better to the touch.
Update:
