Hi, I'm working on a classic nose rider and in the template creation phase. I'm 100% ripping off Harbour to create my outline and I'm wondering if I shouldn't be doing this.
I've worked up an Adobe Illustrator template file that allows me to get within a 1/4 inch of the published specs, and photos.
Pretty new at this, so aiming not to step on too many toes.
Thanks,
Mike
A tipping app?
There are better solutions. The thing to remember about using pics off the internet is that they don't always exactly scale, and its common for the pics to be of the same model but in different dimensions.
https://sourceforge.net/projects/boardcad/#:~:text=BoardCAD%20is%20an%20....
As for the ethics of emulating designs other people have developed, most board builders have been doing that all along. Rich Harbour didn't come up with that general planshape, but he certainly tweaked it to fit his design ethos. In that respect what he ended up with was at least a little different than what he started with.
I''ve mapped many designs from the pros over the years. I didn't build or even intend to build most of them; I was just sussing out different design elements. Not just in the templates but also in the other elements like rockers and thicknesses and so on. I have never "copied" anyone else's design; I always tweaked things to my own tastes. That doesn't count the times I started with a blank file and did my own, which even as a backyarder has been far more common than not.
Unless you're selling boards in direct competition to the labels you love the most they're losing to a "copy" is a single shaping fee. Not to mention the fact that it's probably not a copy to begin with; no matter how hard you try some elements will end up different. You might end up with a good shape but it won't be exactly the same. Jy advice is to use those designs as a starting point for your own vision, not as a paint-by-numbers copy.
This is helpful, thank you for the reassurance. And to your point, there is no way mine will be nearly as dialed in as Harbours. That's actually a really good point about scale and perspective, the photo itself tends to warp things a bit based on how the pic was taken.
Would you recco board cad over AKU?
I think Mike Doyle wrote in his book that Pat Curran once caught him trying to copy one of Pat's Gun templates. Relating to Harbor; There's the Bigler story of the Yater "Spoon" that became the Harbor "Cheater". Lowel
Forget the damned computer. Get yourself a sheet of Masonite, a pencil, a square and a flexible straight edge. Get some basic measurements and start there.
I feel ya, I'm a graphic designer so it's just second nature. Masonite is my next step. I've done a few masonite templates so far with just points, and then blending and I've not been 100% satisfied with the contour of the nose - and wanted to nail this one.
A quick follow-up question for you. What is a good flexible straight edge to use? I've tried scraps of masonite - but it wants to lift in the middle for some reason. Also tried an electrician fish-wire, which didn't quite have the right bend. Also tried to just freehand it, which turned out how you might imagine.
Thanks for the advice.
Technically known as a spline, you can use a nice clear piece of pine or poplar molding, sail battens, a narrow and thin strip of plexiglass, I've even heard of folks using fishing rod blanks in a pinch.
These are expensive but come in handy for refining nose and tail.
https://www.draftingsuppliesdew.com/acu-arc-adjustable-spline-curves
Thank you! Going to try molding 1st, then plexiglass (there is a shop in town with scraps).
A fiberglass batten from a sail is my first choice. You may be able to get one from someone who is or has been a Sailboarder. I'm sure they are used on the sails of small sailboats as well. You can also find 48" metal rulers at Lowes. Lowes and Home Depot sell 8' metal straight edge. Usually one inch wide, 8' long and1/4" thick. You can rip a piece of 1/4" hardwood on a table saw. But by far I love my Sailboard "Batten" and have a variety of them in various thickness(flex) and length.. they were inherited from a deceased brother in law who was an avid Sailboarder. Lowel
I've made templates using Gimp and Photoshop using the same basic method as the original poster. Its important to understand that photography provides a distorted view compared to an actual template and you have to be able to figure out how to accomodate for the distortion. Bear in mind that your bottom rocker creates a longer line along the stringer than if you measure the deck side for instance. The board below was made off of a picture of a 70s board using this process.
