Is it always needed when glassing with epoxy or does it depend on the core material? Why do polyester boards have no vent? does XPS shrink and expand from heat? cheers Marcus
eps must be vented ,if you buy an eps unvented your going to have problems ,vents solve a variety of possible problems...yes its core related only. regards BERT
Hey Low volume XPS or styro doesn't need venting. Unfortunately, that applies to kiteboards and wakeboards. Poly core never needs venting. XPS/sealed styro needs are up to the maker, as some use vents, others don't. Regular styro core usually needs venting. Vents are problematic, at best, on surfboards.
Hollow boards need venting, particularly if travelling on airplanes. A friend of mine just told me this morning of a shaper he knows that built a hollow balsa board down in Ecuador and flew back to California with it. It didn't make the trip very well...basically exploded.
WE have made a few epoxy boards without vents. basically if you keep the core moisture free and out of temperature extremes you should have no problem.
well id say make a few more, see how many come back after crew have dinged them and got em waterlogged ,or left them in there car on a hot day and theve blown up,or just got surfed as usual and coz of no vent have expanded and contracted everyday and fatigued to hell, or delamed under the foot area coz its been hammered and its the weakest spot when theres a little pressure build up thats the first place to go.... vents keep em in pristine condition ,its only then they can outlast a conventional board 10 times at least.... ps my current shortboard has outlived at least 20 conventional polyester pu boards.... do the right thing and vent them... regards BERT
i get my own made coz everything commercially available doesnt stand up....i have aluminium bungs cnc machined and i mould the threaded female insert from epoxy and milled fibre.....for 15.00 aud i could post you the whole assembly plus postage cost as well of coarse.... regards BERT
Thank you for your offer, but I live in France, so I guess I'm better off trying to set up my own system. What's the best location for the vent : nearby the nose ? Inside the fin box ? Pierre
I need a vent plug everytime I contemplate responding to one of FatPenguin Boys rambling ads.
you and me both! but if I had one for that purpose, I can think of several places to use it, if you get my drift...
Any tips about what vent system to choose and the best place to put the vent ? Pierre
