Trying to find an online source for the composite (plastic) cutaway fins. I'd rather experiment with a cheap one instead of plunking down $40+ for something I might not even like. Thanks
This is going to sound crazy but it works. Go to walmart and buy plastic cutting board a little bit thicker than your fin box and go to town.The only disatvantage to this is if you are used to glass fins this will have alot of flex. If you can when you foil the fin in it's thickest spot don't take the cutting board down any. Good luck and have fun
Check out surfsource.net They have several under $10.00
