E-type fiberglass
4 posts |
shaka.brah's picture
Is all E-Type fiberglass the same ?? Can this be used to glass a board ???
Thanks, Skip .....
This fiberglass is E-type, and is compatible with both polyester and epoxy resins. E-type fiberglass is the most common type of fiberglass. If someone doesn't specify the "type" of fiberglass, then it is most likely E-type.
This woven Fiberglass Cloth is commonly used when a thin, smooth, lightweight, transparent, and waterproof coating is desired. It can be layered for additional strength and abrasion resistance. It is often used for covering boat hulls, cabins, decks, and making structural filleted joints. It can also be used for a multitude of other purposes, including but not limited to modeling, automotive, and aircraft applications. It also works great for the construction of composite components.
The features of this fiberglass includes:
  • Roll of woven fiberglass cloth (E-type) with approximately 16 weaves per inch.
  • Compatible with epoxy and polyester resins.
  • Cloth weight: approximately 6 oz per square yard.
  • Cloth roll length: approximately 20 yards (60 feet).
  • Roll width: 1 meter (approximately 39-1/2").
  • Roll diameter: approximately 3-1/2".
gregloehr's picture
E- glass is the standard fiberglass that's used in almost every application. All e-glass is basically the same but it can be woven into a myriad of different fabrics and can be finished in numerous ways to achieve different end products.
surflab's picture
there is a finishing attribute to all fiberglass, that add sounds like something unsure, you might want to ask if they know how its finished, some regular glass has a yellowish tinge that will show in your boards.
So your suggestion would be to stay from that deal ??
