Blank discrepency
First time board builder here so I’ll probably be asking lots of dumb questions in the near future. Forgive me.
First question: I have a board blank whose listed rocker measurements are different from the numbers that I’m measuring here at home. I must’ve measured a dozen times and I’m even re-leveling my blank and straight edge. Is there any chance that the blank is not “true” or is definitely my error?
You hav to shape de blank to find the rocker within.
It’s a possibility… it’s also highly likely your measuring the rocker incorrectly.
How are you measuring it?
Is the blank a natural  rocker blank? Or an adjusted one?
I’m not sure. It’s a Greenlight F series.
im using a level and a square aluminum tube for a straight edge.
Kazuma Surfboards on YouTube recommends balancing the board on one harness of the stand so I tried that too.
i too feel like it must be my error, but idk how
How big is the blank?
how big is your rocker bar?
what should it measure?
what do you measure?
Another way to do it is to just lay the blank on the ground and measure it from nose to ground tail to ground. I know it sounds too easy but it works good enough for ballpark…
^^ That’s what I’ve always done.  I measure my finished boards the same way - Hillbilly-style.
You would be suprised at what “Hillbilly” taught me that.
Blank is 6’
bar is 8’
supposed to be 4 1/2 nose tip and 2 1/8” tail tip.
im getting 5” nose and 1 1/2” tail
Have you tried setting the blank on the floor to see where it actually balances?
So the discrepancy is -1/8” total or 1/16” nose and 1/16” tail.  Sounds pretty close to me.
Put away the level
^^^^ I always wondered if that was a reasonable way to look at  that curve.  Now I know.
Level is only relative to something else that’s either level or plumb.  I don’t understand it’s use of a level for this…  The floor method is better but still affected by foam distribution which is unrelated to rocker but effects how the blank sits due to weight distribution. Things always get complicated when really annualized.  I call the thickest point the apex,  I don’t know if that’s right or not but it gives me a point of reference that’s consistent.
As long as your reference point is the same you’ll get consistent numbers from board to board.
I think most blank companies take their measurements from center of blank (unless told otherwise) That usually coincides with their  thickest point as well.
When I shift the thickness I shift my point of rocker references as well
a long way to say I do what Gene stated above
i saw a rocker table once  pretty cool -
totally flat - center was 0 and had 6’ tape measures going out on both sides - put your thickest point on 0 and take measurements at any point  in either direction
Mounted at eye level -
measure with a flat bottom
Just my 2c…  This has been discussed on Sways since forever…  If you have been keeping records, great.  If you want to become a good shaper you need a consistent system.  I learned my from the HI shapers when they came to the mainland in summer to shape a long time ago.  It is so simple and accurate that I’m still surprised that people are still placing blanks on the floor….
Step#1:  Find the center of the blank by measuring up from the tail.  Mark the center.  All of the West Coast  blank makers set rocker from center.  Just look at the catalogs.
Step#2:  Place your level centered on your mark, then slide the blank on the racks until it sits level.  I have a dedicated level I use only for shaping.
Step#3:  Place your rocker stick (which should have a center mark at 4’) centered on the blank.  Take your measurements.  If you are measuring a blank greater than 8’, you can slide it up or down and put pressure on the center point of the blank and be pretty accurate.  I use a 10’ extruded aluminum channel since I do lots of long boards.
Remember that too much pressure shaping and/or glassing can alter the rocker at tip & tail a bit.  A tolerance of +/- 1/16”  is really pretty good.  All blanks are cut & glued up by hand.  In my opinion Nose/Tail tolerances are not as important as 6” up & 6” back.  You can change nose/tail measurements by a simple pass of the planer and not affect board performance much if at all.  Back in the 04-05 post Clark era,  blanks were all over the place, so as a newer shaper, consider yourself lucky!  Again, just my 2c……
Blank nor straight edge need to be level.  Famous Swaylocks guy Lee Vanderhurst finally convinced me that there is ONLY ONE point at which the straight edge will be tangental to the midpoint.  Various blank thicknesses and rocker will make placing the blank “level” the work of the devil himself.  Another famous Swaylocks guy (Bill Barnfield) covered this in detail and advised that a blank can be standing in the corner of the room and this process can still be accomplished.  I have gotten damn close with a ‘too short’ straight edge when measuring rocker for a 12’6" paddle/surf hybrid… by ‘shimming’ the straight edge with a block several feet away from the midpoint and sliding the straight edge to the end of the blank.  As long as the end of the stick is still touching the midpoint, you’re good to go.  None of these methods will hold up to micrometer readings but who cares?  Once you glass the thing it’s gonna pull the rocker a bit anyway.  And yes, we nearly started WWIII over this several years ago…  http://web.archive.org/web/20100601095417/http://www2.swaylocks.com/node/1009636?page=1
John;  I understand what you are saying, that’s why I put that note in Step #3.  When I started to do a lot of hp longboards back in the 90’s I needed a system that was quick and accurate time and time again.  I spend just minutes checking rocker on a hand shape with my system.  That’s what I’m trying to pass on to DublAK2…  Had a visit from Bill back then and he approved what I was doing.  Don’t know what else to say, with most of the young guys getting boards cut they don’t really care what the rocker is off the machine.  Just scrub and done.  I don’t have many more years of shaping left, but what I do make I want it to be the best it can be.  You couldn’t do better than starting out with level solid racks and accurate measurements.  Just my 2c…
Agreed. Best thing about this thread is that rocker is even being measured.  I’ve heard it said (and agree) that the rocker points at 12" and 24" at either side of midpoint are worth double checking. There is always room for more than your basic end point measurements…  figure out a system and use it.
Good to know that someone does it the same way I’ve always done it.
Also: “In my opinion Nose/Tail tolerances are not as important as 6” up & 6” back.” are words of wisdom, too.
