Nose Rider Pig
Nose rider pig 9’6" x 23" x 3 5/8". Reverse tail rocker, concave nose bottom, vee bottom tail, leash loop through the fin box, 10" hatchet fin, yellow foam stain, acrylic nose rider bands set at 24". Designed by Rex Khawaii, old school design incorporated modern LONGBOARD concepts. No hard edges.
This one is made for breaks like Queens, Pops, Canoes, Threes, White Plains, small Makaha for that real old school of surfing, fading, drop knee turns, cross stepping and nose riding.  If your feet are on the color bands and/or anything front of that you are nose riding.
When Morey conducted the first Noseriding Invitational the rules stated that the nose was the front quarter of the board. That’s why many of the early noserider models had a lateral stripe at the nose or solid color at the front, only. The 10’2" Hobie I used to own had a solid blue nose that covered the front 30.5". So the nose on this board, if you apply that old rule, is at 28.5" from the tip.
I’m guessing poly? Curious about the acrylic bands; are they just acrylic paint or mixed into the resin? What brand of acrylic?
MTN acrylic spray paint  on the sanded hot coat.  It is like airbrush in a can.
The local noseriding contests is set at 24"  from the tip of the nose.
Beautiful workmanship.       Over the years you have posted a number of very interesting, and well executed projects.     Thanks for  sharing.
I agree with everyone before.  Beautiful.  How much tail rocker and what did you do to conform the fin box to the tail rocker?  Thanks for posting.
all the best
N 3 13/16  T 3 5/8 rocker.  I cut the hole for the future fin box slightly deeper (about 1 mm) to make up for the tail rocker. Fill the flange with resin and milled fibers to make it level with the foam.   6 oz patch over the fin box and then glassed over with a full layer of 6 oz.   It took me a while to get the Future center installation dialed in.
Haven’t done a “strong box” yet,  but I have heard that tail rocker and V can be an issue.  Looks like you compensated for it nicely.  Lowel
Resinhead told me to try that for crisper graphics too, on top of the fill/hot coat, but I have yet to try it. I heard other good things about Montana paints too.
D, I also really enjoy your various board projects and your ‘look’ with the bright colors and rice papers.
How many coats? Did you sand between coats? Did you sand the paint before gloss?
Sand hot coat.  Paint, gloss coat.I did not sand the paint.
It took me and my surfboard building buddy Rex about 4 hours to dial in the router and future center fin jig…  This one came out the best. We drop the fin box just a hair below the foam.  we then fill in the flange with resin and millled fibers.
I saw a trick on Josh Martins IG where he used a heat gun to bend to the rocker of the tail. It works. I always have trouble with boxes and tail rocker. The heat gum is a good solution.
all the best
