Almost done my first board. Have been reading Swaylocks religiously but still messed up my freelaps for lam coat. The bottom is pretty flawless, but the top had a bunch of fiberglass strings and bumps that I didn’t sand down fully (should have basted, I realize now). Hotcoat went on fine and seemed alright, but when I started to sand it down I got some immediate burn throughs on the bumps.
I was hoping to not do another coat (no gloss coat planned either) but I believe I need to do it.
What I’ve done now is sanded down the entire deck to be pretty much perfectly flat / level now. No bumps, etc.
The issue, the thing I’m wondering about, is that while sanding I can see the fiberglass weave, but when I clear away the dust, while not exposed (as in, I can’t touch and feel fiberglass), it is visible underneath the thin layer of epoxy from the lam / hot coat.
See photos for reference.
Full quality imgur album here: https://imgur.com/a/StFIx5n
Here is one of the photos:
[[{“fid”:“117349”,“view_mode”:“default”,“fields”:{“format”:“default”,“alignment”:“”,“field_file_image_alt_text[und][0][value]”:false,“field_file_image_title_text[und][0][value]”:false},“type”:“media”,“field_deltas”:{“2”:{“format”:“default”,“alignment”:“”,“field_file_image_alt_text[und][0][value]”:false,“field_file_image_title_text[und][0][value]”:false}},“link_text”:null,“attributes”:{“class”:“media-element file-default”,“data-delta”:“2”}}]]
My question is: should I continue sanding down and fully expose these fiberglass parts? Would that help improve the appearance?
My thought process is: if I sand down further, and fiberglass is exposed (I don’t know if it really would be exposed or not though), the next coat of resin can get in further and saturate the glass / area better.
The board looks good other than the rails / nose / tail (hah). It’s a shame my glassing job turned out bad.
Is there a way to salvage this and fix up these problem areas? Will a second hot coat help cover this up enough?
