Ah- replying to two in one here -
First off, of late, what with great whites becoming part of the local… well, not landscape, seascape… around here, i’ve been wandering back to something I did before I got into surfing: motorcycles.
How is this relevant? When you mentioned a lovely scar acrss the lower back I kinda shuddered, what you can do to your back on rocks and such ain’t good. But for guys that race motorcycles, or ride on asphalt, or recycled ol’ coots like me, they make armour, plastic and rubber stuff that fits under your other gear, does help with impacts. They make (among other things) a vest that’s meant to protect the back and the spine.
Now, it’s a sand bottom here, but for the times I surfed shallow rocks, I bought a helmet. Were I doing that rock game again, I might look into such armor. Like I did for the bike. I have enough back problems, and I kinda like walking.
But to resins - good question, by the way - really, either straight gloss or hotcoat followed by gloss. Depending on how deep it winds up being. The reason being that you’ll have to sand anything you put in before the gloss, which eliminates laminating resin.
What catalyst to use? I would go with the minimum amount of MEKP. MEKP because you can control it better as it hardens. UV resins have always acted for me like "Hey, surprise, it’s hardened’.
Minimal amount and letting it go off slowly so that - well, if you think of resin as, say, ropes and the catalyst as somebody splicing them together, a few guys splicing a given number of ropes leads to relatively long ropes while a lot of guys splicing and you have shorter segments. Or, if you like, the resin as steel pieces and the catalyst as a welder, a few welders working steadily make for long pieces welded up. Those longer…ropes, steel, whatever… correspond to longer polymer chains formed in the hardened resin, which makes for a tougher, stronger plastic .once it’s hardened that will flex more without cracking.
Wow, there’s some tortured analogies-anyhow-
Hardened resin that goes off real fast tends to be brittle. Short polymer chains. Plus the reaction gives off heat and if it’s a thick layer then that heat pushes the reaction even faster so even shorter polymer chains ( and more heat, it gets ugly) are formed.
Longer is better
