Hi,
I’m trying to work out a process of transferring my designs onto the exterior of a fin. You can see an image of one of the fins below using rice paper which isn’t as perfect as I’d like.
I’ve experimented with rice paper printing and laying it down underneath the final coat of resin, but the resin itself isn’t heavy enough to weight it down uniformly and it either stiffens up the fin too much, or you just end up going through the layer of resin back onto the fin beneath. That’s the image I’ve posted.
I then tried laying it underneath a final layer of glass, but again it stiffens up too much especially across the tip and is hard to get looking uniform across the whole fin.
So after googling away a couple hours, I found the below video from Alkali where they stamp their logos and some more text on the outside of the fin as the final production step.
https://vimeo.com/162301902
Does anyone know what kind of ink they would use? Is waterproof ink suitable for saltwater use?
Cheers, Michael
PS the fins in that video go insane, especially in a board with a pulled in swallow, and modern rails!
